Has anybody here done the alfa 75 twin spark engine change to 74 gtv? i am having problem with coils not sparking also one of my coils got so hot that it melt down.any idea??
thank you
sam
thank you
sam
The system is stock with amplifier and ecm , it has 12v on +ve side of coil but not on -ve side with ign on and engine off. no spark from coils but injectors firing as i crank the engine.turbolarespider said:Sam,
How is your ignition set up???
If you are burning up coils, it sounds like they are on 100% of the time, never switching off- which sends the power to spark the spark....
Do you have points?
Check out the ignition thread on this same section- it shows the basic points electrical layout.
If you are using the stock trigger, you need a computer to deal with that- as far as I know, all of the 75's TS ignition is electronic, and requires at least an amplifier, if not a module to turn the 100-2 pulse weel into a ignition system....
Eric
